Jd955 No start
/ Jd955 No start #1
Sld1261
955 JD
My 955 bogged down while my wife was mowing and wouldnt restart. I changed fuel out, compression is good. I pulled the injectors out since i found radiator leaking thinking head gasket. Blows black smoke out tail pipe while cranking. Any ideas would be appreciated
/ Jd955 No start #2
Hi, and welcome to TBN. Black smoke frequently indicates too much fuel for too little air. Check your air cleaner then the air path through the intake. Sometimes it really is that simple.
/ Jd955 No start
I've got the air intake off, i changed the fuel out, I even took the inje3ctors out and hooked them back up the the fuel lines and cranked it over. Injectors all had good spray patterns. I took it to an ag shop and they said the head gasket was bad, I doubted that because I had already pulled the injectors and put air in the cyl's and it didn't come out anywhere it shouldn't have. Since i had nowhere to go I pulled the head off (which was simple)to find out nothing was wrong with the gasket, head or block. I also pulled the plate off the front of the motor and checked the injection pump marks- ok. I have no idea where to check next cam/crank marks? It just seems so damn funny thatthis thing has ran like a clock since it was new and I'm **** about servicing it and now this happens. 1034 hrs at this point so i don't understand whats happened. This thiong should have ran alot longer than this without problems like this. Anybody have any ideas?
429136 (A61166)
429136 (A61166)
2022 BOBCAT E35 R2-SERIES PLATINUM EXCAVATOR (A62129)
2022 BOBCAT E35...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2009 Peterbilt 367 Flat Bed (A64047)
2009 Peterbilt 367...
2019 ISUZU MPR HD 18' BOX REEFER TRUCK (A62130)
2019 ISUZU MPR HD...
UNUSED JCT DUSTLESS BLASTER (A62131)
UNUSED JCT...
