JD955 Mid Mower Lift Arm Problem
   / JD955 Mid Mower Lift Arm Problem #1
sroberts
Olathe, Ks
John Deere 955, 70A FEL, 72" MMM, 59 Snowblower, 1953 Farmall Super C w/Woods 72" Belly Mower
Can't get the Mid Mower lift arms to lower on my JD955. Lift arms are at top height. Have taken operator station panel off and messed with the height adjustment nut but no go. It does have a mid cylinder lift system which may be the problem. Anyone have this issue before? Is there a way to lock the mower lift arms? Just for grins I put loader on and hydraulics work for it fine which pointed me to the mid cylinder. Have also adjusted the rockshaft relief valve. Three point lift works fine too.
   / JD955 Mid Mower Lift Arm Problem #2
The mid lift cylinder works off of the same scv as the loader bucket ciircuit, so if the loader bucket works, the mower lift should as well. You say you "messed with" the height adjustment. Can you turn it easily? Turning the height adjustment counter clockwise will allow mower to lower further. You need to have mower lifted all the way to adjust it.
Height adjustment moves both ways easily and loader bucket works all ways using scv lever but mid mower lift arms won't budge at all. Mower is not on tractor because connection arms won't reach to mid mower lift arms.
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
Pallet Fees (A50774)
2021 Dosko 337S-13HC Walk-Behind Stump Grinder (A49461)
2021 Dosko...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
