JD790 loader
/ JD790 loader #1
John Weaver
Georgia
2000 JD 790
I have been considering buying a loader for my JD790. Can I drive into a pile of gravel or dirt and get a full bucket? Is it built sturdy, or do I need to be concerned with bending something? What is break out force? Anyone near middle Georgia willing to let me see some projects you have done with your loader? Guess I have lots of questions, but I know there is lots of experiance out there. John.
/ JD790 loader #2
John,
I have a 410 loader, and it may bend a little but I don't think it would do any damage, it would bend back. I drove into 1,000 of rock piles with mine and still going. Cliff
I'm moving up to a 5205!
/ JD790 loader #3
I have a JD 790 with the 70 loader with 54" bucket and removal tooth bar. I have spent over 100 hours moving a hill from one side of the drive to the other (still have more to move), the hill is Virginia clay that hasn't been distrubed for years, the tractor and loader has preformed flawlessly, with no apparent bending of the loader arms, but I have bent the top of the bucket knocking down trees. If you are going to be digging in the dirt the tooth bar makes a BIG difference, like cutting butter with a hot knife, for moving gravel, its not really needed. One thing that you will need is weight on the rear, up until last month I used a 490# box blade, now I have loaded rear tires (around 560#) and with the box blade still attached, it digs even better. I would highly recommend the loader. Hope this helps.
/ JD790 loader #4
I have a 60" 410 with a toothbar for my 4100. I use a concrete filled JD Ballast box (about 500 lbs). I have moved gravel, road millings, and leveled out a small area for equipment storage. It has done very well. No complaints.
Terry
/ JD790 loader
Thanks for the replys. Sounds like a # 70 loader may be the next purchase. Could someone explain what a tooth bar looks like, how it attaches and if it is an option from JD or do I get one somewhere else, or build it? John.
/ JD790 loader #6
John,
A tooth bar goes along the edge of the bucket, and it has teeth like on a backhoe bucket. I'm pretty sure you can get one from Deere, but someone else probably has a picture of one to show you what it is like.
/ JD790 loader
I went to JD dealer (lots of stuff to look at). He priced a # 70 loader with brackets, hood guard and bucket level indicator for $2600. installed. He only has 48 inch bucket. Should I get him to order the 54 inch bucket? Your thoughts? John
/ JD790 loader #9
John, I have used my 70 loader on my 790 for almost a year.
So far it has doen everything I have asked it to do and not a single problem. I use mine for just about everything from clearing snow, cleaning the barn to digging holes and landscaping. I did get the 60" bucket to cover the tire tracks and use my back blade for ballast. Rick
/ JD790 loader #10
John,
Go to this previous post where to get a toothbar.
I purchased one a couple of months ago and it cost me $325 for the unit, custom cutting, and shipping. This JD dealer was very helpful and prompt. I had the unit with two weeks after placing the order.
Good luck - Terry
/ JD790 loader #11
John, unless you specifically need a narrower bucket, I'd go for the 60" to cover your tires. I've got the 70 loader with 60" bucket on my 790 and it's a mean, green digging machine /w3tcompact/icons/smile.gif
/ JD790 loader #12
My 2 cents is to get the wider bucket. I'd think you would at least want the bucket a few inches wider than the machine. Can't think of any reasons to get the narrow bucket if the machine will handle the larger one, which yours would.
Chris
4400HST, Canopy, 72" Deck, 516 Cutter, 420 Loader, 6' Blade, Homemade Sprayer, Boom Blade
1958 JD 620 Restored
/ JD790 loader
I called the dealer. The 54 inch bucket is $35. extra and the 60 inch is $55. extra. Since cost is not an issue, I think I will get one bigger than the standard 4 foot bucket. The rear wheels are 5 foot. My only concern is that I assume with a smaller bucket I could do a better job pushing into a pile of material. Of course, this could just be my newbe thinking. Better to make the right decision now when the cost to upsize is cheep. John.
/ JD790 loader
I did it. Ordered a # 70 loader with 54 inch bucket and bucket level indicator. I ordered an operators manual for the loader before I pruchased. The manual talks about 700+ lbs. of weight on 3ph, weights on rear wheels and loaded tires. Is all this necessary? For the guys with 790's, how much weight do you use and where do you put it? John
/ JD790 loader #15
To expand on my above post - when I first got my JD790 (like to call it that because everyone thinks that I have one of the big hoes, and to be its my big hoe, better than a shovel) I had no weight on the back, and no tooth bar, really had trouble digging, wheels would spin very easily when trying to dig. Could only skim off the dirt in thin layers. Got a tooth bar and it helped the digging, but the wheels would spin easily. Purchased a Bush Hog 5' box blade, about 490 pounds, added it to the 3 point, really made a difference. Also found I needed weight for keeping the rear wheels on the ground with a bucket of wet dirt or manure. Later purchased a Bush Hog 7' scraper blade, tried it, found it to bulky hanging out back, but it did about as good as the box blade. Purchased a Worksaver Fork attachment this summer, found the box blade was not enough when lifting at full capacity of the loader, so I loaded my rear wheels (R4's) with 5 gallons of methanol and 28 gallons of water each, giving me about 260 pounds in each tire. This is great, sorry I didn't load at the start - able to dig with out the box blade, and with the blade this thing really hugs the ground and will cut more than it can move. So my recommendation is load your rear tires, then look at implements with weight that will also be of some use to you.
By the way it only cost me $14 for the tool at NAPA (adapts garden hose to valve stem) and $40 for the methanol to load my rear tires. Cheaper than any implement.
/ JD790 loader
The dealer finally got my new loader installed and delivered it yesterday. It was here when I got home from out of town. Played (worked) all day today. Now I know why everyone with a FEL says they could not do without it. BTW I know in the last 73 posts I have asked many more questions than I have answered. Thanks to all you guys for the information. I still consider myself a newby. John.
/ JD790 loader #17
Way to go John. Yes, I bet you're loving that loader. I've been a bit tractor-deprived lately (busy) but I did use my FEL to take the fifth-wheel hitch out of my truck yesterday. Didn't take long, but I was all smiles for those few minutes /w3tcompact/icons/smile.gif
ROOM WITH MISC ITEMS (A67714)
ROOM WITH MISC...
2007 Mack CHN613 (A64911)
2007 Mack CHN613...
2015 Kubota M6-131 131HP 4WD Agricultural Tractor (A66734)
2015 Kubota M6-131...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
