JD790/419 Loader drifting down
   / JD790/419 Loader drifting down #1
gaspumpman
JD 790 w/ 419 FEL
We have a JD 790 with a 419 loader. If we leave our bucket elevated or in the air, over a 12 to 18 hour period it drops to the ground. For example, we leave the bucket up above the hood (36" off of the ground) and in 12 hours the bucket will be on the ground. Is this normal?
If we remember correctly it did not do this when we purchased it new. The JD dealer and rep has told us this is acceptable and normal.
Thanks,
Scott
   / JD790/419 Loader drifting down #2
MOST loaders will have some leakdown, and i have seen some that will stay up for hours with no leakdown. they say it is acceptable for it to leakdown. am not that faimilair with the 790 but it does not seem excessive PERHAPS SOME JD OWNERS WILL be able to advise you better.
   / JD790/419 Loader drifting down #3
Some leakdown is considered normal - as long as it is within spec. Here's a link to a Deere page with the 'official' method of testing - and some sample acceptable leakdown rates. Your 419 is not listed but you could take it that you should be in this ballpark:
Deere Loader Leakdown Rates
   / JD790/419 Loader drifting down #4
Just out of curiousity...why would any one want to leave their loaders extended?
I always drop mine down when the engine is off, or the machine is going to set idle .
Not really sure I know what you folks' intent is here...
I am not sure why, other than to see if it will remain extended. I don't guess we have a legitimate reason. Just curious...
   / JD790/419 Loader drifting down #6
I just hate it when people leave their loaders up in the air. /forums/images/graemlins/smile.gif I alway have to walk around a tractor and I always hit my head when the loader is left up. /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
My New Holland TC29D will drop also. It is normal for every model.
murph
   / JD790/419 Loader drifting down #7
leakdown is common for any make/model of loader no matter how old or new. and will get gradually worse the older it gets. the reason for leaving the loader up in the air is to keep pressure on the seals. without this pressure the seals may become loose enough to have a slow leak.
matt
   / JD790/419 Loader drifting down #8
"the reason for leaving the loader up in the air is to keep pressure on the seals. without this pressure the seals may become loose enough to have a slow leak."
Interesting concept...can't say I've ever seen a loader left up when the tractor engine is off.
Seems too dangerous to me, since the loader would freefall if someone hit the joystick when climbing onboard, or egressing.
My old 670 never had leaking seals..after about 12, 13 years of use.
   / JD790/419 Loader drifting down #9
if you think about it, it makes sense. many mechanics around this area very strongly believe this. i have always left the 3 pt. up on my tractors when ihave cultivators, hillers, shredders, etc. hooked up. it is dangerous but usually i set it about 6 inches off the ground and the same with the loader. loaders arent that heavy compared to how much the cylinders can lift, so there really isnt that much pressure on the seals.
matt
   / JD790/419 Loader drifting down #10
Another instance where an old wives tale is spread by a mechanic (although it can be spread by anyone).
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
