JD770 4x4 compact
   / JD770 4x4 compact #11
"It's still a good motor as all Yanmar motors are."
They sure are!
Even with just 19 HP (16.5 at the PTO), this little engine is a worker! I've yet to run out of power, but lack of traction can be a problem. And it sure is frugal with diesel fuel too!
Of course, one of my pipe dreams is putting that 770 engine in my tractor (if I could find a good used engine). Same frame..maybe different engine mounts and definitely a different injection pump. But it would be a doable project if I ever need to replace the engine.
I did price out swapping to a dual stage clutch, but when the dollars got above $1500, I gave up on that idea. Can't really say I miss having a dual stage. About the only thing I have to accomodate is when I'm finish mowing, I may have to back over areas where I'd clutched for a turn or shifted a gear. The inertia of the rotary cutter blades is enough that clutching is no problem...no problem with loader work either.
   / JD770 4x4 compact
Darn! Sold before I could get a look at it! A JD 855 which is also a 24 hp Yanmar has surfaced close by. Gonna call about it. Thanks again for the responses on the 770.
DMB
   / JD770 4x4 compact #13
" JD 855 which is also a 24 hp Yanmar has surfaced close by. Gonna call about it"
Also a very good tractor. Expect the 855 to have a higher price due to the hydrostatic transmission.
The only thing I don't care for on the x55 series Deeres is the placement of the head lamps (low, on the rear fenders just outboard the operator station). If you have a loader, they get blocked by the loader masts.
Great tractor though, and they really hold their value...
   / JD770 4x4 compact #14
We took in a 955 not too long ago and I had the chance to drive it. Cool machine and great turing radius. This one had the 420 FEL on it. Overall, not a bad machine.
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2023 FG INDUSTRY STE 35SR MINI EXCAVATOR (A51222)
2023 FG INDUSTRY...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2010 POLARIS RANGER 4X4 4 SEATER UTV (A51222)
2010 POLARIS...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
