Mowing JD757 melting rear decal ?
   / JD757 melting rear decal ? #1
DP Property
BelleRiver, Ontario
Kubota B7510, JD GT235, JD 757, JD Gator 850D, JD 3720 hi-spec cab on order
I have a 2005 757 I purchased used this year. The machine itself only had 210 hours on the 18 horse Kawi. I did notice the last E in John Deere was half missing and the paint looked messed up there. I guessed the first owner had dropped something on it or it had got banged up in a trailer. I removed the decal cleaned everything up and lightly sanded the bad area. Then applied primer and JD green and a new decal.
I now have 310 hrs on the machine this season and I notice the E is starting to melt and the paint is getting messed up again under the E in that one area.
It is strange because it is not that close to the exhaust pipe but there is a 90 degree bend in the pipe and the point of the 90 I think directs heat to that one spot. Has anyone else with a 757 had this problem and if JD does not make a heat deflector what should I use to try and deflect the heat away from that one area?
FAKE (A52472)
FAKE (A52472)
Gehl 2580 Round Baler (A50774)
Gehl 2580 Round...
2018 MDB LV600 GREEN CLIMBER (A51406)
2018 MDB LV600...
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A51572)
1995 Chevrolet...
2014 PJ TRAILER 40' TANDEM AXLE GOOSENECK (A52472)
2014 PJ TRAILER...
Husky Tandem Tank Spreader (A50774)
Husky Tandem Tank...
