Mowing JD757 melting rear decal ?
   / JD757 melting rear decal ? #1
DP Property
BelleRiver, Ontario
Kubota B7510, JD GT235, JD 757, JD Gator 850D, JD 3720 hi-spec cab on order
I have a 2005 757 I purchased used this year. The machine itself only had 210 hours on the 18 horse Kawi. I did notice the last E in John Deere was half missing and the paint looked messed up there. I guessed the first owner had dropped something on it or it had got banged up in a trailer. I removed the decal cleaned everything up and lightly sanded the bad area. Then applied primer and JD green and a new decal.
I now have 310 hrs on the machine this season and I notice the E is starting to melt and the paint is getting messed up again under the E in that one area.
It is strange because it is not that close to the exhaust pipe but there is a 90 degree bend in the pipe and the point of the 90 I think directs heat to that one spot. Has anyone else with a 757 had this problem and if JD does not make a heat deflector what should I use to try and deflect the heat away from that one area?
2021 KYRV (A50324)
2021 KYRV (A50324)
2004 EAST GENESIS TIPPER TRAILER (A52141)
2004 EAST GENESIS...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
