Loader JD750 with 67 Loader - Bucket Replacement
   / JD750 with 67 Loader - Bucket Replacement #1
SwingOak
Central Wisconsin & in the Western UP, MI
'65 IH Cub Lo-Boy, '13 Kioti DK50SE HST, '20 Kioti RX7320
I put a new bucket on my dad's JD 750 with 67 loader last weekend. I struggled to find a replacement that came with the same 4 pin mounts like the original, so I had to do it the hard way.
I bought a new 60" utility tractor bucket designed as a replacement for compact tractors. I thought what I ordered had a quick attach plate on it, but it turns out that it did not. I was originally planning on converting the 67 loader to a quick attach mount and would need a QA plate for that, so I bought a quick attach plate from Amazon. Looks like the factory cut a QA plate off this bucket before they shipped it to me too, which seems kind of silly.
The 750 only has a lift rating of I think 700 lbs, so extra weight was potentially an issue. I decided not to add quick attach mounts to the tractor because it is not something my dad really needs, but if that changes I can just cut the mounts off and weld them to a quick attach mount. I needed to weld the QA plate to the bucket anyway as a stiffener and to have a heavier gauge plate to weld the brackets to.
In the end, it saved me about $250 to buy and weld my own QA plate on, so that worked out OK.
I cut the mounting brackets out of the old bucket:
Cut them off to mount to the flat back of the bucket, and welded them to the QA plate, shown here prior to welding. I left the bucket back on as a stiffener and this way I didn't have to worry about the bracket spacing, only the distance between them:
Welded & painted:
And it worked out OK:
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
2022 Coras Predator Steel End Dump Trailer (A56438)
2022 Coras...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
