Tires JD4720 Wheel & Tire Spacing
   / JD4720 Wheel & Tire Spacing #1
Highlander
Washington State
JD 4300/430 Loader
Owning a 4300HST with a 430 Loader for the past four years, I have now logged over 900hrs on this machine using the loader for approx. two thirds of the time, I soon discovered the superior stability provided by reversing my front wheels on the R-4 tires to the widest position. Presently mulling the purchase of /forums/images/graemlins/smile.gif another tractor come next spring, I am looking at the 4720 for a number of reasons but have noticed an anomoly in the wheel and tire spacing when the R-1 tires are mounted. It appears that there is but one(1) inch of offset on the 8.00-16 6PR R-1(Rim p/n AM127369) versus the four(4)inches provided by reversing the 10.00-16.5 6PR R-4 T1 (Rim p/n AM127368). Why is there no virtually no offset when using the R-1 Tires??? I enjoy this added stability and often wonder why John Deere would offer 8 positions on the rear wheels but no options on the front? Could I use another wheel or am I doomed to use no more offset and a narrow front end regardless of what I do with the rear? I really do not want the R-4 tires unless I have to as the tractor will be out in the field mowing, cultivating, seeding and fertilizing and light baling when required outside of it's normal gardening chores!
   / JD4720 Wheel & Tire Spacing #2
<font color="blue">Why is there no virtually no offset when using the R-1 Tires??? </font>
The reason is that when you offset the front wheels, you are greatly increasing the stress on the entire front end especially the bearings. I am sure that if you check, most compact tractor manuals state that front wheels with Ag tires are only allowed in one position.
No offense intended, I went back to the Deere manual for the 4720 and it allows for a narrow and wide R-1 wheel configurations on the front end, however the difference is only 1 inch compared to the 4 inches for the R-4 tires. I find it odd, that for the tire tread alone, John Deere must feel there is sufficient bearing support for R-4's over the R-1 tires. Perhaps it is due to the tire slippage with the R-4's, but the off-set difference is still hard to explain. /forums/images/graemlins/frown.gif
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2022 Mack MD Danco 12R22 22FT Rollback Truck (A50323)
2022 Mack MD Danco...
We do NOT accept credit cards as payment. (A50121)
We do NOT accept...
Deere 333G (A50120)
Deere 333G (A50120)
ATTENTION PLEASE READ (A50120)
ATTENTION PLEASE...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52748)
2000 John Deere...
