So, yesterday I was digging a ditch with my 4600 and everything was going just great. I had been piling up muddy soil on the road from the ditch and eventually needed to get the machine to the other side of the muddy pile. So I just drove the tractor over and through the mud. The mud pile was deep enough to reach the rear axle and ooze in around some of the lower parts of the rear end. I was having to help push the machine over the mud with the backhoe. It was at this point when the engine just abruptly quit and wouldn't even crank over. When I turned the key from off to run, the familiar fuel shut off solenoid click wasn't happening. I know that this is not due to the thermister, because I have replaced the thermister with a pushbutton, and the thermister would not inhibit the engine from cranking over.
After some thought I figured that the most urgent thing was to get the machine out of the mud so it could dry out. By removing the fuel shutoff solenoid and hot-wiring the starter, I was able to get it running again and get it out and the mud hosed off. I'm not sure if the mud is a factor in this, but I figured I'd include it because at this point I don't know what's going on.
Any ideas on what interlock is in there that would even inhibit cranking the engine? Would the seat switch do this? On my tractor, there is no seat switch.
