JD455 Blower Shaft Ext Slipped out...wtf?
   / JD455 Blower Shaft Ext Slipped out...wtf? #1
vmurray
Canada
John Deere
JD455 Blower Shaft Ext Slipped out...wt...?
Wow, I made a mess of the shaft extension on our first snow fall. Shaft slipped out somehow - lifted too high maybe? - and slapped around on the QH plate chewing up the ends of the teeth on the shaft.
I got lucky with a little filing work and got her sliding back in nicely on the second attempt at cleanup.
Just don't understand how that happened. Any advice to prevent in future would be appreciated.
I took some measurements before/after re-install and based on the numbers in a variety of positions, I can't see how this happened. Shaft is 4.75" at teeth and insert is roughly 1.6" (1 5/8"). The slip connector to the long shaft was still intact and firmly seated.
Just unusual bad luck or something I'm doing wrong.... Thoughts?
Thanks in advance!
   / JD455 Blower Shaft Ext Slipped out...wtf? #2
Re: JD455 Blower Shaft Ext Slipped out...wt...?
I presume that you put the u-joints back in phase(time)? According to parts photo shaft has a timing pin. I think it might be wise to put a hyd cylinder stroke limit on snow blower so this won't happen again.
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
CATERPILLAR D3K2 LGP CRAWLER DOZER (A51242)
CATERPILLAR D3K2...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
BULLDOZER ROOT RAKE (A51243)
BULLDOZER ROOT...
