JD4300 manual sez 50/50 mix of antifreeze&H2O?
   / JD4300 manual sez 50/50 mix of antifreeze&H2O? #1
samhudson3
Central NC, Southern part of Heaven
John Deere 4300
Hi all, it's time to change the antifreeze in my JD 4300 (HST/diesel) and the manual calls for a mix of 50% antifreeze / 50% mix of water. Just wondering why that is?
   / JD4300 manual sez 50/50 mix of antifreeze&H2O? #2
That's the mix for most everything.
If you buy straight coolant, you mix it 50/50 with water. Or you can buy premixed that is already 50/50 and just pour it in.
Straight coolant is cheaper than pre mix. Keep that in mind, a gallon of concentrate makes two gallons of finshed product once you mix it with water.
Straight coolant doesn't cool the engine as well and the engine is not intended to run with it. 50/50 mix is good for freeze protection well below zero and cools the engine the best as well.
   / JD4300 manual sez 50/50 mix of antifreeze&H2O? #3
As Dusty said, Plus, Straight anti freeze does NOT work, and it can burn...65% was the maximum on most stuff, in extreme areas?
Thanks for the explanation, gentlemen. My mechanical know-how is somewhat limited (my dad could barely make coffee) and I lean pretty hard on the TBN community! :thumbsup:
   / JD4300 manual sez 50/50 mix of antifreeze&H2O? #5
These days, perhaps. I still remember 70/30 from my Minnesota years. It was so cold one morning, I opened my hood to find out why the starter solenoid wouldn't even click. Found a burst battery. -35F froze the battery, but 70% anti-freeze at least saved me from a split heat exchanger or a pushed out freeze plug.
That said, I'm sure anti-freeze/coolant formulations have improved considerably since those days.
//greg//
   / JD4300 manual sez 50/50 mix of antifreeze&H2O? #6
Just how cold does it get in NC...? We use 50/50 up here, good for -40F...
We've had a mild winter here in the Piedmont of NC. I've got a pear tree that's started blooming and spring peepers have been singing. We're now zone 7b on the new USDA map, lowest temp down to 15F.
Gotta cold front moving in tomorrow, down to 23F with winds of 30-35 in the forecast, coldest weather of the season. Wood rack loaded, so no worries.
   / JD4300 manual sez 50/50 mix of antifreeze&H2O? #9
1F here at 10am, spring is coming, getting warmer..
   / JD4300 manual sez 50/50 mix of antifreeze&H2O? #10
Remember that Diesel may require a special antifreeze. For water try and use only demineralized water.:)
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A52576)
2019 FREIGHTLINER...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
10x16.5 Tire Assembly (A53472)
10x16.5 Tire...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
