JD4300 front end loarder problem
   / JD4300 front end loarder problem #1
wirewheel
JD 4300
Top of the world to all on this 9/11 day !!!!! The US is still here and will be for
a long time. My issues my 4300 front end loader and the rock bar will not lift up.
I've check the fluid (had to add 2qt) still will not lift more then 3 inches (sometimes). Do I need to bleed the unite if so were would that be? Thanks:confused2:
   / JD4300 front end loarder problem #2
Welcome to TBN. :)
   / JD4300 front end loarder problem #3
Most times these problems are fixed by unseating all the QD's (quick disconnects) and then reconnecting them. They can "look" coupled when they are really not.
   / JD4300 front end loarder problem #4
Welcome to TBN!!!
Follow Kenny's instructions and report back, if necessary...
   / JD4300 front end loarder problem #5
Hello & WELCOME to TBN!
I moved your thread to the John Deere Owning/Operating Forum. :)
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
Pallet of Turnbuckles (A50860)
Pallet of...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
