JD4300 and Marvel Mystery Oil
   / JD4300 and Marvel Mystery Oil #1
paulcapasso
Connecticut
2000 JD 4300 / 2006 155C
Using Marvel Mystery Oil as a diesel additive. Any ideas recommendations or regrets?
   / JD4300 and Marvel Mystery Oil #2
buy your self a lottery ticket same result, if you are having engine or fuel system problems look somewhere else. Marvel Mystery Oil is good as a lubrication oil but so is any thin oil is but your money soon to be theirs
   / JD4300 and Marvel Mystery Oil #3
Using the marvel oil to do what? Are you having a problem that leads you to using this addative?
   / JD4300 and Marvel Mystery Oil #4
I have always heard it's great for you're injector pump.
   / JD4300 and Marvel Mystery Oil #5
This thread may take off soon lol, the diesel additive debate lol.
I don't believe marvel would do any damage to a system but I also don't think it would do much good, the quantity you would use would get expensive.
I have a 05 4320 and I add a small bottle of 2 cycle to the tank, idk if it helps it mechanically but I mainly use it because the tractor is noticeably quieter and smoother, I don't add nearly as much as people say to add, my tank is 10 gallons and I add like a 2-3 oz little bottle in there after I fill up, every time I do she settles down a bit while idling.
   / JD4300 and Marvel Mystery Oil #6
Marvel is Great for breaking loose stuck engines or cheaper yet acetone and brake fluid mixed together
there was a big thread on this a while back concerning additives for wear reduction,
iirc there was a linked test with data suggesting that bio diesel was more effective than many of the expensive additives.
yeah- good chance there are some (differing) opinions on diesel additives :laughing:
TROYBILT TB51BP GAS BACKPACK BLOWER (A51248)
TROYBILT TB51BP...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
2019 Ford Explorer SUV (A51694)
2019 Ford Explorer...
2016 WACKER NEUSON LTV6 PORTABLE LIGHT TOWER (A51247)
2016 WACKER NEUSON...
