JD420 govener set up
   / JD420 govener set up #1
trialsguy
Kansas City Mo. area
YM226D
I have a 420 lawn tractor and I am having a issue with the govenor I think. It pulses preety bad at low rpm, like the govenor is messing up so I thought I would see about the ajustment procedure and check to see if it is adjusted right, although I do suspect the carb is out of adjustment a little bit.
Had a clogged jet in the carb, cleaned it up and she run alot smoother
   / JD420 govener set up #4
yep, put a fuel filter in line between the pump and the carb to prevent this from happening again.
71059 (A49346)
71059 (A49346)
2010 International 4400 National Crane 300C Crane Truck (A50323)
2010 International...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A51039)
2019 Energreen EVO...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
