Comparison JD4110 versus Kubota B7500
   / JD4110 versus Kubota B7500
I just bought a B7500 with FEL and BH. I on the other hand decided to keep my JD325 to mow the lawn with. If I had tried to use the 7500 on my yard, it would have really tore it up because of the moisture. If I waited until it was dry enough to mow with the 7500, well I still wouldn't have cut my grass this year.
   / JD4110 versus Kubota B7500 #22
I think it all depends on your application. For me, I could never mow my lawn with the B7500. I have a JD LX277 that does a great job. The B7500 would make a mess out of my lawn with the R4's and moisture we have in the NW. I also have used the lawn tractor with a trailer as a "dump truck" when using my backhoe. It's nice to have both.
Greg
Thanks for the info everyone. I certainly have more food for thought.
At this rate, when I finally make my final decision on the tractor, I will be armed with total knowledge....., well, maybe not total knowledge, /forums/images/graemlins/wink.gif, but certainly more knowledge than I had before.
Garick
   / JD4110 versus Kubota B7500 #24
Garick.
KEEP THE LAWN TRACTOR as long as it performs to your satisfaction. It will be kinder to wet turf than the B7500. My CFO does the lawn cutting and I do the rough stuff. Without that lawn tractor, I would have to maintain the lawn which would cut into my fun stuff. I hate cutting the lawn. Would rather play in the soil. Its a win-win situation /forums/images/graemlins/smile.gif.
Ken
Is the Kubota b7500 similar to a BX22 Kubota, I am shopping for a new tractor and haven't really nailed it down yet.I would like a backhoe and I would like a bigger tractor.Is the B7800 tractor a lot larger and harder to maneuver. I like the horsepower, the three point hitch lift. and the loader lift.
   / JD4110 versus Kubota B7500 #26
You came to the right place to find out all the little differences in tractors. You will get more response if you ask the question on a new thread. If you like Kubota it would be best started in that forum. I am new and learning so I will leave the opinions to the rest of the group. It is fun learning together.
   / JD4110 versus Kubota B7500 #27
David, the B7500 is a compact tractor as opposed to the BX-22 sub-compact class. The BX22 does have a backhoe however. You can get a backhoe for the B7500 if needed. The B7800 is in the largest class of compacts and will cost a bit more. In order to get the best advice from these very knowledgable folks, you need to tell us what you plan to do with a tractor /forums/images/graemlins/smile.gif.
Ken
   / JD4110 versus Kubota B7500 #28
Have you checked out the KIOTI LB1914 or the CK 20 yet?
I just ordered the LB1914. Should be here soon and I'm chewing at the bit to give it heck /forums/images/graemlins/smile.gif
13,200 = 54"loader w/tooth bar, 5' finish mower and 55" tiller.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
Hot Pressure Washing Equipment Set (A56857)
Hot Pressure...
2018 Kaufman 20-Ton Equipment Trailer, VIN # 5VGAP2528JL004708 (A57453)
2018 Kaufman...
2005 John Deere 330C LC (A55272)
2005 John Deere...
yellow ball Trailer (A56859)
yellow ball...
