Comparison JD4110 versus Kubota B7500
   / JD4110 versus Kubota B7500 #11
<font color="blue"> I was quite surprised to see a tractor of that size with a backhoe </font>
It does look a little funky, doesn't it? BH makes the tractor look pretty small. But they work great - I love mine /forums/images/graemlins/smile.gif.
Thanks for the pictures Greg. Now you got me thinking about what I could use a backhoe for.
Garick
   / JD4110 versus Kubota B7500 #13
BACKHOES are nice, and i wish i could justify the cost for the amt. of time i would use it, but i can't /forums/images/graemlins/frown.gif just remember that although they have BH for those size tractors they are not really made for a steady diet of BHwork, this of course is just MHO
   / JD4110 versus Kubota B7500 #14
forgot to mention: might be helpful to fill out your profile in a little more detail. will help the guys get a better iea of your needs. BTW welcome to the forum /forums/images/graemlins/smile.gif
   / JD4110 versus Kubota B7500 #15
They are both nice tractors and you would be happy with either one. The only possible concern I would have is what would happen to parts availability should Deere decide that someone other than Yanmar should be building their tractors....
   / JD4110 versus Kubota B7500 #16
Garick,
Before I purchased my 4110, I looked very seriously at the 7500. I test drove one a couple of times and really liked it. I went JD because the dealer has an excellent reputation and is only 6 miles from my home.
A few things that I like better about my 4110:
Position Control - you can get by without but I think it sure helps you to minimize the stones in your yard while plowing the drive in the winter.
The twin touch hydro pedals were more comfortable to me.
I felt the seat was more comfortable.
Auto bleed fuel - just never let it run out and this option is a non-factor.
There were a couple of things I liked better about the 7500:
Full flat deck - the 4110 has a small hump.
Price - the 7500 was a little cheaper.
Good luck with your decision, both are great machines that will give you years of service.
Thanks for the information everyone. I have found this forum to be of immense value in learning about tractors.
We are still waiting for the JD dealer to get their stock in. They are a small town dealership, so I don't mind waiting since I would like to give them the business rather than go into the city (Calgary, Alberta) to the larger dealerships.
I do have a question though. In my reading of this forum, I see a number of poeple are also buying the mowers for the tractors.
I currently own a JD 345 which I thought I would keep to mow the lawn. The lawn is a bit hilly, but nothing to steep. I wasn't considering using the compact for mowing thinking it might be too large to do a decent job, and since I was considering the R4 tires, thought these tires might damage the lawn.
Am I out to lunch here? Should I consider getting a mower with the tractor and selling my JD 345 since it would be redundant?
Garick
   / JD4110 versus Kubota B7500 #18
Garick
</font><font color="blue" class="small">( I currently own a JD 345 which I thought I would keep to mow the lawn. )</font>
If your current machine is adequate for your mowing needs and does it in a timely fashion, keep using it. I don't use my B2910 for mowing. I only mow about 2/3 acre and my small Honda lawn tractor has been doing that for 16 years now and just keeps on going strong.
I have, on occassion, found it handy to tow a 17 cu. ft. utlity cart behind my lawn tractor while using the larger tractor with loader and backhoe. For instance, when digging out an area to sink some landscape timbers, I scooped out the area with the backhoe and dumped the spoils in the cart. Worked really well.
Just my $0.02.
Good Luck,
~Rick
   / JD4110 versus Kubota B7500 #19
I traded my JD GT235 in on a new 4110. I decided to spend the $1700 or so on a 60" mmm instead of keeping my GT. My yard is also a little hilly, but I'm sure the 4110 with the mmm will do a good job mowing. When I test drove the 4110, I compared its turning radius with the 60" mmm to the turning radius of my GT235 with its 48" mower and they were nearly identical.
I have R4s on my 4110 and they don't harm the yard. Because the weight of the 4110 is a lot heavier than the GT235 was, I have to be more careful about driving on a wet yard. The 4110 will really dig in even if the yard is moderately wet.
All in all, I decided to trade in the GT235 because I didn't want to hassle with 2 machines to maintain.
Let me know if you have any other questions.
Heath
I use to use an L2900 on about a 3/4 of an acre. It was easy on the grass. I am now using my B2910 on it which is smaller and lighter and it works great. The R4's won't hurt your grass unless its wet or you make a really sharp turn and a good rate of speed. The B7500 is smaller than the B2910 so I would imagine that to be even better on grass. I would sell the JD and get the finish mower. I would get a 5ft RFM. That is just my opinion. MMM cost more and are harder to unhook. They are about the same to use I think. Good luck with your decision.
Dave
Est. 2000-2005 CAT 60 6K lb Capacity Forklift (A59213)
Est. 2000-2005 CAT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
5ft Bench Seat (A57454)
5ft Bench Seat...
UNUSED IRGC40 HIGH END MINI GOLF CART (A58376)
UNUSED IRGC40 HIGH...
Voltage Converter, Single Phase, 240 Volt Input, 120 Volt Output (A59076)
Voltage Converter...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
