JD4100 Quick Hitch Dimensions
   / JD4100 Quick Hitch Dimensions #1
HD4010
Cannonsburg Michigan
Hi,
This might sound like an odd request but I wonder if there is anyone what can tell me the approximate dimensions for the quick hitch for the 4100. I'm looking at buying one of the net and want to get estimated shipping costs but need dimensions.
What is the approximate overall:
Width
Length
Overall height
Height in front where implements attach
Length of the upright piece where that attached to tractor.
I'm thinking if the pin was removed for the hydraulic cylinder and the pin that connects tractor interface to the implement interface it might be cheaper to ship both parts separately vs the whole thing together as it seems like shipper prices are more dependant on volume than weight.
Thanks in advance for any help that may be offered.
HD
   / JD4100 Quick Hitch Dimensions #2
I am a little confused:confused:
Are you looking for something for the FEL or the 3PH? If it's for the loader, then what isn't the JD QA system doing for you?
If it's for the 3PH, then look HERE
Hi,
I`m referring to the front quick hitch that you would use with a front snow blade, snowblower, etc.
Regards,
HD
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
Killbros 260 Seed Conveyor (A51039)
Killbros 260 Seed...
196046 (A50459)
196046 (A50459)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
