JD4010, JD2210, or GC2300
   / JD4010, JD2210, or GC2300 #11
Sounds like a nice setup. Did the dealer think you would need a rear implement to offset the weight of a loaded FEL? How about some photos when you can? Good luck.
I will try to post some photos.
The dealer suggested a box blade to be used on the back, but I think I will make a 3 pt hitch ballast out of concrete.
2022 Case IH Steiger 420HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
