Backhoe JD400 in aus
   / JD400 in aus #11
   / JD400 in aus
i agree with the email address but i can not see how to remove it
   / JD400 in aus #13
There is a certain period of time (maybe 24 hours) that you can edit your own post.. and the word "Edit Post" is there to click..
but you have to go to that post to do it.
   / JD400 in aus #14
It all depends on what you want to use it for. I have a very tired 400 as well and while it doesn’t do precision work anymore it will do in one pass what takes 6 or 8 passes with my B7510.
If you can get it to running condition with a little effort and not much money you will be able to get lots done and have a little fun doing it.
There are some experts here and on GTT that know a lot about that machine.
Good luck
   / JD400 in aus
i may never go its pretty bad , ill pull the head off n have a look
AGT SAII100 SKID STEER QUICK ATTACH 48" (A57193)
AGT SAII100 SKID...
2004 IC Corporation 3000IC School Bus (A55852)
2004 IC...
2012 Ford Explorer (A53317)
2012 Ford Explorer...
2016 Peterbilt 597 Wet Kit Tri-Axle Day Cab Truck Tractor (A55852)
2016 Peterbilt 597...
2010 JLG E450AJ TELESCOPIC/SCISSORING MANLIFT (A52707)
2010 JLG E450AJ...
Ratchet Straps (A55852)
Ratchet Straps...
