JD400 Backhoe hydraulic oil flow seems reversed?.
   / JD400 Backhoe hydraulic oil flow seems reversed?. #11
I can't remember the shim spec's. Several yrs back I was in a discussion on this site(I think) with a fellow from Houston,Tx that had a JD 2155(IIRC) that posted the shim spec's. All those closed center steering valves such as your tractor are very similar in design. I'll suggest to try a search on Google or this site.
Thanks again TX Jim, you have been most patient in sorting my problems. I'll now post another request on this site to try and find those shim clearance specs and also try Google.
2015 KC TRAILER 130 BBL STEEL VACUUM (A50854)
2015 KC TRAILER...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
