JD345 pro won’t disengage
   / JD345 pro won’t disengage #1
345milo
JD345 watercooled
I was wondering if anybody had this happen, my clutch is maybe 3 yrsold worked great until this week, went to mow first time ,took blade off, put deck on ,started tractor blades engaged,checked switch ,ok,thinking something rusted up overwinter,do I need to take clutch off and clean it or can u even get it apart to do so?
   / JD345 pro won’t disengage #2
   / JD345 pro won’t disengage #3
Maybe if you run it for a few, the clutch will disengage?
   / JD345 pro won’t disengage #4
Typically, it's the bearings in the clutch are rusted and thus always engaged.
You could try disconnecting the clutch connector at the clutch and then try again. Seems unlikely that the power to the clutch is stuck on. If it was, your battery would be dead the next day.
Richard
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
NEW Wolverine 72in Skid Steer Ripper (A59000)
NEW Wolverine 72in...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
1999 Dodge Ram1500 ST Ext. Cab Pickup Truck (A56858)
1999 Dodge Ram1500...
