JD3320 fuel pump or fuel injection pump
   / JD3320 fuel pump or fuel injection pump #1
b20135
Bluemont, VA
deere 3320
does the JD 3320 have a fuel pump or a fuel injection pump or both? I search on a fuel pump for a 3320 results in a approx $30 fuel pump and a search on a fuel injection pump results in a $650 pump??
   / JD3320 fuel pump or fuel injection pump #2
Really it has three 菟umps you have an electric fuel pump drawing from the tank and pushing fuel up to the filter assembly and beyond, them there is a mechanical pump bolted to the side of the injection pump, and then the injection pump itself. FYI, an injection pump is going to be more like $3,000-4000
Are you having trouble? I have a PDF of the technical manual for your tractor, if wanted shoot me your email
Joe
   / JD3320 fuel pump or fuel injection pump #3
The injection pump is made by Yanmar.. it has a sticker name plate w/ the p# on the side of the pump.. search that #..
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
Kubota BX2230D (A47384)
Kubota BX2230D...
RYOBI EASY START INVERTER GENERATOR (A51248)
RYOBI EASY START...
