JD310C Owner/Operator/Mechanic
   / JD310C Owner/Operator/Mechanic #1
Rmbentley
Minford, OH
John Deere 310C
Ran fine in morning, shut off, tried to starter later, cranked over but would not start. A while since fuel filter change, so now changed, still will not start.
Seems as thought fuel solenoid will not open valve for fuel flow. Fuel flow is a small pencil lead size flow to mechanical fuel pump. Cannot hear solenoid clunk. Where is the solenoid located?
   / JD310C Owner/Operator/Mechanic #2
Welcome to TBN.
Not a Deere owner, but look for any wires going to your injection pump that might indicate a solenoid location. Sounds like you're on the right track, looking for the clunk of the 'noid.
   / JD310C Owner/Operator/Mechanic #3
:welcome:
Welcome to the forum!
I'm going to move your thread over to our John Deere section. Someone over there should know the specifics.
Confidence, confidence. Dirty fuse box. Cleaned, horn never work, now it does. Tried to start, just cranked, no fire. But I heard the solenoid clunk. Ready to call in an expert!!! Oh no. This cab is just to messy for an expert to see. So I began throwing things out the window...wait a can of ether. Try that. Squirted some into the air intake on the hood. It fired, coughed, and missed, stalled after ether used up---but it kept running and began to run smooth. Just air in the fuel lines.
   / JD310C Owner/Operator/Mechanic #5
Thanks for letting us know you got it running again.
:welcome:
   / JD310C Owner/Operator/Mechanic #6
Welcome to TBN
I'll suggest you only use ether as a starting aid as a very last resort. I suggest to use the ether starting aid if your tractor came equipped with it because the aid has an orifice limiting amount of ether that engine can ingest at on e time. The top rings on pistons are very easy to break lowering compression ratio using ether sprayed into air cleaner or intake.
2015 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A56858)
2015 Chevrolet...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
2016 Nissan Pathfinder SUV (A56859)
2016 Nissan...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2018 FREIGHTLINER...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A55315)
2022 Brush Wolf...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
