JD3020 LP Fluid change.
   / JD3020 LP Fluid change. #1
imabass
Pawnee, OK
JD 3020 Propane
I recently purchased a 64 3020 propane. I have only put about 30 hours on it but I am planning on doing a complete fluid change this weekend so I have a good baseline of when everything was changed and to get a better understanding of where everything is. I busted a remote hydraulic line under the foot plate and have the new one to replace it. Figured since my oil level is already low, now is a good time to replace everything more for peace of mind and while I have the time to do it.
I have a 800 or so page manual at home but I was going to stop on my way home to purchase the fluids. Going home is quite the drive so trying to save a hour and half trip to the farm supply.
I am not sure which engine oil to use or hydraulic oil to use? 15w40 engine oil? Is the diesel oil fine for the LP engine? I would assume that it is.
Looks like 8 gallons of 303 hydraulic fluid. I think they sell these for about $30/ 5 gallon. Any reason why I should use the JD vs generic stuff that is sold at the farm store?
Any other recommendations while I am doing the fluid/filter service?
   / JD3020 LP Fluid change. #2
Nice looking 3020.
   / JD3020 LP Fluid change. #3
I use JD Hy-gard in my 4255 but 303 spec oil is fine for your 3020.I'd suggest to also change hyd filter & check/clean sump screen.
   / JD3020 LP Fluid change. #4
I thought 303 was bad stuff?
   / JD3020 LP Fluid change. #5
303(spec J20A) was the correct spec for early JD tractors built from '61-'72. Later model JD tractors need oil that meets Hy-Gard spec's(J20C).
   / JD3020 LP Fluid change. #6
Nice looking tractor for sure,, looks like it is low hours.
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2020 Chevrolet...
2012 Chevrolet Express 3500 Passenger Van (A55973)
2012 Chevrolet...
WARN VR8000 WINCH (A58374)
WARN VR8000 WINCH...
PALLET OF HOSE & WIRE (A58374)
PALLET OF HOSE &...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
NEW Fork Extensions (A59000)
NEW Fork...
