JD3020 hydrolic fittings on remote
   / JD3020 hydrolic fittings on remote #1
MilesMc
Marion Center,PA
JD 2030
we recently bought this jd 3020 it works great only issue we have is it doesnt take the pioneer fittings on our attachments anyone know what type of fitting it takes or if their is an adapter to take pioneer fittings thanks in advance for the onfo
   / JD3020 hydrolic fittings on remote #2
You might have better luck on the answer with this over in the hydraulic section.
   / JD3020 hydrolic fittings on remote #3
   / JD3020 hydrolic fittings on remote #4
The ISO conversions seldom worked to the user's satisfaction (leakage). Use adapter couplings or change the tips on your hoses if you only use the attachment on the JD. Anyone dealing in aftermarket tractor parts can get either for you.
Thanks all will be getting the adapters btw anyone else who needs them in the northeast Tractor supply stocks them :thumbsup:
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
71069 (A49346)
71069 (A49346)
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
3in Poly Pipe (A49461)
