JD300B hose from Hydraulic filter to Transmission Help?
   / JD300B hose from Hydraulic filter to Transmission Help? #11
Get a 5000# gauge with a short hose. Connect hose to orifice where plug(key 24) is located on RH side of hyd pump. Connector size required is 0.375 IN/24 TPI/ORB
Okay I will buy and test it out.
Right now what was wrong was the hydraulic fluid was really milky and had a hole in a line squirting fluid. I changed the hose. Now changed out the milky fluid, transmission filter & hydraulic filter.
When I move either of the Backhoe levers somewhere below has a loud continues vibration Thud like sound.
   / JD300B hose from Hydraulic filter to Transmission Help? #13
Did you check/clean hyd oil sump screen?
I got it pulled out just a little and it looked clean. I could not get the whole thing out because it was stuck and would only spin but would not pull out.
   / JD300B hose from Hydraulic filter to Transmission Help? #15
Screen should pull out of trans case if not clogged or crumpled.
Yea it only came out maybe half an inch? Then was stuck in there and I didn't want to rip it out and break a piece off inside so I just slid it back in and put the fluid in. The fluid was so milky and the filters was so tore up I figured that alone may do the trick.
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2011 CATERPILLAR 303.5 D CR EXCAVATOR (A51242)
2011 CATERPILLAR...
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A51222)
2025 REDEDLIFT...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2008 NEW HOLLAND B95 BACKHOE (A51242)
2008 NEW HOLLAND...
2011 CATERPILLAR 259B3 SKID STEER (A51242)
2011 CATERPILLAR...
