jd2940 moves at a crawl pace
   / jd2940 moves at a crawl pace #1
jd2940
I was using a chisel with my JD 2940 when all of a sudden it slowed down to a crawl. I checked the hydralic oil and found it to be milky.
(not sure how that happen but will have to investigate thatlater)
I figured maybe something got clogged so I changed the the hydralic oil and filters, but it still moves at a crawl pace. I noticed the brake
pedals were kind of hard so I bled them. Still no difference ( still hard). I can shift to all gears and move in all gears but it moves like a snail. Hydralics seem to be working fine. Does anyone have any suggestions on what could be the problem. Looking for ideas on things to check while I start saving money if major repairs need.
Thanks in advance.
   / jd2940 moves at a crawl pace #2
does the engine rev higher when you depress the accelerator? if it doesn't-it must be a fuel related issue, if it revs and goes nowhere-clutch or trans issue. good luck
Found out I had busted seals on the main line that feeds the pressure regulating valve under the transmission shift cover. Thats where I was loosing all my pressure.
Thanks for responding.
2004 Ferrara Pumper Fire Truck (A51692)
2004 Ferrara...
2016 Wells Cargo Enclosed Trailer (A53117)
2016 Wells Cargo...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
30in Forks and Frame Mini Skid Steer Attachment (A51691)
30in Forks and...
