jd2940 moves at a crawl pace
   / jd2940 moves at a crawl pace #1
jd2940
I was using a chisel with my JD 2940 when all of a sudden it slowed down to a crawl. I checked the hydralic oil and found it to be milky.
(not sure how that happen but will have to investigate thatlater)
I figured maybe something got clogged so I changed the the hydralic oil and filters, but it still moves at a crawl pace. I noticed the brake
pedals were kind of hard so I bled them. Still no difference ( still hard). I can shift to all gears and move in all gears but it moves like a snail. Hydralics seem to be working fine. Does anyone have any suggestions on what could be the problem. Looking for ideas on things to check while I start saving money if major repairs need.
Thanks in advance.
   / jd2940 moves at a crawl pace #2
does the engine rev higher when you depress the accelerator? if it doesn't-it must be a fuel related issue, if it revs and goes nowhere-clutch or trans issue. good luck
Found out I had busted seals on the main line that feeds the pressure regulating valve under the transmission shift cover. Thats where I was loosing all my pressure.
Thanks for responding.
2017 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 DRAGON 130...
2015 FORD E350 16FT BOX TRUCK (A53426)
2015 FORD E350...
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
2020 Bell B30E Off Road Dump Truck (A53117)
2020 Bell B30E Off...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
City of Lakeland (A51691)
City of Lakeland...
