JD2640 Hi Lo shifter problem
   / JD2640 Hi Lo shifter problem #1
FaithFarmPaul
Green Bay, Virginia
JD2640
Hi Everyone,
I am a new member & first time post.
Today I was trying to shift from low to park
to unhook my bush hog when my shift stick
pulled completely out of the socket. The tractor
is now locked in low gearing, also 4 rings attached
to the rod came out with it which two apeared to be
slightly bent. I replaced the rod and tried to shift but
the trans is locked in low. How can I reinsert and align ?
Thanks for the help.
Paul
To all who may experience this problem,
I went to my local JD Dealer in Burkeville, VA.
for a bushing, snap ring kit which is what broke.
The kit diagram explained the order but I first
had to line up the proper gear. The trans was in
low gear so the shifter handle must face right forward
which allows the rod to slide in easily. One bushing,
two shims and the snap ring installed all was well.
I cranked up the JD and away I went.
Today I replace an old brake line which cracked while
bush hoging the edge of my field.
Paul
   / JD2640 Hi Lo shifter problem #3
Glad you got it all fixed up!
And Welcome To TBN /forums/images/graemlins/grin.gif
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A50322)
2017 Caterpillar...
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
2014 John Deere 700K LGP Dozer (RIDE AND DRIVE) (A50774)
2014 John Deere...
2015 John Deere 135G Hydraulic Excavator (A50322)
2015 John Deere...
