JD2320 Pulling power
   / JD2320 Pulling power #1
JDGREEN1
Does this seem right?
My manual says the 2320 weighs 1,660 lbs. If you want to tow a trailer with brakes it can tow 4.5 times it痴 weight 7,470 lbs. Trailer with no brakes 1.5 times it痴 weight 2,490 lbs.
   / JD2320 Pulling power #2
Seems reasonable to me as far as being able to tow the load. However, I would temper that with my own judgement based on the specific conditions. For instance, nomatter what the book says, I wouldn't try towing 4.5 times the tractor's weight on a grassy slope or something like that.
I move a 5,000 lb boat around with a lawn tractor, but only on flat concrete.
   / JD2320 Pulling power #3
If you want to tow a trailer with brakes it can tow 4.5 times itç—´ weight 7,470 lbs.
What is going to operate the brakes? A typical inertia-type controller will not work well or at all on a tractor...
   / JD2320 Pulling power #5
If you load the tractor up, like with a loader and box blade then you can tow 4.5 times that amount. It's just a matter of traction. Still you've got to be careful due to braking.
   / JD2320 Pulling power #6
I think they're talking about a trailer with onboard surge-type brakes. I've rented trailers from U-Haul with them. When the tow vehicle slows, the trailer brakes activate -- it's all mechanical/hydraulic with no electrical connections needed.
   / JD2320 Pulling power #7
When I had my 4110, I would pull around our 29' Fountian using a reciever on the three point. It was great for moving it in and out of the barn since I could see very well and get it tight to the wall. You had to be in low range, and it stopped it well (trailer had surge brakes, but I dobt they worked at slow speed). I only moved the boat 100' or so, and would never move it anywhere but from the barn to the driveway.
So I have no doubt you can move a 7K trailer.... But I would not tow it down the road......
1997 FIAT ALLIS FG65C MOTORGRADER (A50458)
1997 FIAT ALLIS...
2013 John Deere 824K (A50397)
2013 John Deere...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A50458)
2015 CATERPILLAR...
28'' Blackstone Air Fryer Combo and Warming Drawer (A48837)
28'' Blackstone...
Engine on Skid (A50860)
Engine on Skid...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
