JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST
   / JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST #1
dmay
Winnipeg, MB
2010 JD2320
With thanks to Kennyd's post and links provided here to posts from lt220, jimgerken and lincolnvt (thanks all for sharing your knowledge)
http://www.tractorbynet.com/forums/...it-selective-control-valve-2.html#post2263359
I am thinking to mount a valve oriented like this:
http://www.tractorbynet.com/forums/...-installing-2-spool-selective-control-051.jpg
With QC's directly attached similar to this:
http://www.tractorbynet.com/forums/...90482529-2520-rear-remotes-added-img_4790.jpg
Here is what I think _might_ be the correct parts list to order:
JOHN DEERE
PT13744 PB PLUG, QTY=1
SURPLUS CENTER
DSCV BLOCK, FRONT PORT
9-6805-6-6 SAE 6M TO 3/8" NPTF 90 ELBOW, QTY=1
DSCV BLOCK, REAR PORT
9-6901-6-6 SAE 6M TO 3/8" NPTF 90 SWIVEL, QTY=1
9-5503-6-63/8" NPTM TO 3/8" NPTF 45 ELBOW, QTY=1
PB HOSES
903-3836 3/8" X 36" 3/8 NPTM X 3/8 NPTM 2750 PSI HYD HOSE, QTY=2
9-A2-172-D 3/8 IN SINGLE WIRE DUAL HYDRAULIC HOSE CLAMP, QTY=1
2 SPOOL VALVE
9-7401 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE, QTY=1
VALVE INLET/OUTLET PORTS TO PB HOSES
9-6901-8-6 SAE 8M x 3/8 NPTF 90 SWIVEL, QTY=2
VALVE WORK PORTS TO DIRECT ATTACHED QUICK COUPLERS
9-6902-8-6 SAE 8M x 3/8 NPTF 45 SWIVEL, QTY=4
9-7184 3/8" NPTM - 3/8" NPTM HEX NIPPLE, QTY=4
9-7381-F 3/8 NPTF QUICK COUPLER, QTY=4
What do you think? Any changes/additions recommended?
   / JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST #3
Are the quick couplers you have listed the same as the john deere ones? I have a jd 4110 and I'm going to put the "home made" power beyond kit on it like kennyd and jim did to theirs and I'd like them all to be the same. This is my first post and I'd like to thank all the guys who took the time to post pics and explain what they did. it was a HUGE head start for me.
   / JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST #4
Welcome to TBN Bandit:D
The QD's I used for mine all came from JD...
   / JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST #5
Thanks, maybe i'll just do that too just to be on the safe side.
   / JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST #6
dmay,
Have you order the parts and done your install yet?
   / JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST #7
hi gtrippleb, i don't mean to butt in here, but i have a jd4110 and i followed all these guys posts and have installed my power beyond and spool valve. if i can help you, i'd be glad to.
dmay,
Not yet. I'm two weeks through a five week evening welding class which is keeping my play time busy. :)
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2009 Mini Cooper Clubman Sedan (A50860)
2009 Mini Cooper...
PHENIX TECH HI POT MACHINE (A50854)
PHENIX TECH HI POT...
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
Killbros 260 Seed Conveyor (A51039)
Killbros 260 Seed...
