JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST
   / JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST #1
dmay
Gold Member
Winnipeg, MB
2010 JD2320
With thanks to Kennyd's post and links provided here to posts from lt220, jimgerken and lincolnvt (thanks all for sharing your knowledge)
http://www.tractorbynet.com/forums/...it-selective-control-valve-2.html#post2263359
I am thinking to mount a valve oriented like this:
http://www.tractorbynet.com/forums/...-installing-2-spool-selective-control-051.jpg
With QC's directly attached similar to this:
http://www.tractorbynet.com/forums/...90482529-2520-rear-remotes-added-img_4790.jpg
Here is what I think _might_ be the correct parts list to order:
JOHN DEERE
PT13744 PB PLUG, QTY=1
SURPLUS CENTER
DSCV BLOCK, FRONT PORT
9-6805-6-6 SAE 6M TO 3/8" NPTF 90 ELBOW, QTY=1
DSCV BLOCK, REAR PORT
9-6901-6-6 SAE 6M TO 3/8" NPTF 90 SWIVEL, QTY=1
9-5503-6-63/8" NPTM TO 3/8" NPTF 45 ELBOW, QTY=1
PB HOSES
903-3836 3/8" X 36" 3/8 NPTM X 3/8 NPTM 2750 PSI HYD HOSE, QTY=2
9-A2-172-D 3/8 IN SINGLE WIRE DUAL HYDRAULIC HOSE CLAMP, QTY=1
2 SPOOL VALVE
9-7401 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE, QTY=1
VALVE INLET/OUTLET PORTS TO PB HOSES
9-6901-8-6 SAE 8M x 3/8 NPTF 90 SWIVEL, QTY=2
VALVE WORK PORTS TO DIRECT ATTACHED QUICK COUPLERS
9-6902-8-6 SAE 8M x 3/8 NPTF 45 SWIVEL, QTY=4
9-7184 3/8" NPTM - 3/8" NPTM HEX NIPPLE, QTY=4
9-7381-F 3/8 NPTF QUICK COUPLER, QTY=4
What do you think? Any changes/additions recommended?
   / JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST #3
Are the quick couplers you have listed the same as the john deere ones? I have a jd 4110 and I'm going to put the "home made" power beyond kit on it like kennyd and jim did to theirs and I'd like them all to be the same. This is my first post and I'd like to thank all the guys who took the time to post pics and explain what they did. it was a HUGE head start for me.
   / JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST #4
Welcome to TBN Bandit:D
The QD's I used for mine all came from JD...
   / JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST #5
Thanks, maybe i'll just do that too just to be on the safe side.
   / JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST #6
dmay,
Have you order the parts and done your install yet?
   / JD2320 - POWER BEYOND OUTLETS TO 2-SPOOL VALVE w. QUICK CONNECTS - PARTS LIST #7
hi gtrippleb, i don't mean to butt in here, but i have a jd4110 and i followed all these guys posts and have installed my power beyond and spool valve. if i can help you, i'd be glad to.
dmay,
Not yet. I'm two weeks through a five week evening welding class which is keeping my play time busy. :)
2015 MACK GU713 (A50854)
2015 MACK GU713...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
2014 Kia Soul SUV (A48082)
2014 Kia Soul SUV...
