JD2305 Seat safety switch bypass failure
   / JD2305 Seat safety switch bypass failure #1
drmt
JD2305
Hi everyone,
Have a JD2305. Tried bypassing seat safety switch so I could run PTO to clean out sprayer without being seated on tractor. Used jumper to bypass switch.
Tractor would turn over and run but not continue to run after I released key. Reconnected seat safety switch but now have same problem: tractor will turn over and run but not continue to run after I release key.
What did I do? What should I do now?
BTW it is a 2 wire seat switch, not a 4 wire switch.
   / JD2305 Seat safety switch bypass failure #2
I'm sorry I can't help with your current problem, but you shouldn't have had to bypass the switch in the first place. With the transmission in neutral and the brakes set, the PTO should have run without anyone in the seat. If that didn't work, there was probably some issue to start with.
Looks like you need to track down the wiring to the solenoids and start sorting the logic out.
   / JD2305 Seat safety switch bypass failure #3
That's a good and simple place to start. Keep it simple and check the fuses and the relays - they're all 'plug in' and in the same area. Relays can be swapped to see if the fault (starting) transfers to somewhere else.
Your Owner Manual will have a diagram of fuse/relay positions and rating.
Thx for your replies. I will try that.
I'm the biggest dummy! I assumed the engine wouldn't turn over if it was a fuse. Wrong. It was a fuse. Thx for your help!
   / JD2305 Seat safety switch bypass failure #6
You're very welcome and thanks for the follow-up. Glad to be of help & that's what TBN is all about.
Sometimes it just takes an extra set of eyes to see the problem.
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2017 JOHN DEERE  30G (A50854)
2017 JOHN DEERE...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2022 John Deere 8RX410 Track Tractor (A50657)
2022 John Deere...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
