JD2305 Seat safety switch bypass failure
   / JD2305 Seat safety switch bypass failure #1
drmt
JD2305
Hi everyone,
Have a JD2305. Tried bypassing seat safety switch so I could run PTO to clean out sprayer without being seated on tractor. Used jumper to bypass switch.
Tractor would turn over and run but not continue to run after I released key. Reconnected seat safety switch but now have same problem: tractor will turn over and run but not continue to run after I release key.
What did I do? What should I do now?
BTW it is a 2 wire seat switch, not a 4 wire switch.
Thanks
   / JD2305 Seat safety switch bypass failure #2
I'm sorry I can't help with your current problem, but you shouldn't have had to bypass the switch in the first place. With the transmission in neutral and the brakes set, the PTO should have run without anyone in the seat. If that didn't work, there was probably some issue to start with.
Looks like you need to track down the wiring to the solenoids and start sorting the logic out.
   / JD2305 Seat safety switch bypass failure #3
That's a good and simple place to start. Keep it simple and check the fuses and the relays - they're all 'plug in' and in the same area. Relays can be swapped to see if the fault (starting) transfers to somewhere else.
Your Owner Manual will have a diagram of fuse/relay positions and rating.
Thx for your replies. I will try that.
I'm the biggest dummy! I assumed the engine wouldn't turn over if it was a fuse. Wrong. It was a fuse. Thx for your help!
   / JD2305 Seat safety switch bypass failure #6
You're very welcome and thanks for the follow-up. Glad to be of help & that's what TBN is all about.
Sometimes it just takes an extra set of eyes to see the problem.
John Deere 16 Row Cultivator (A50514)
John Deere 16 Row...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
2006 INTERNATIONAL PAYSTAR 5500I KILL TRUCK (A50854)
2006 INTERNATIONAL...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2018 FORD EXPEDITION (A51406)
2018 FORD...
3HP Electric Fans (A50854)
3HP Electric Fans...
