JD2305 PTO will not start
   / JD2305 PTO will not start #1
SI2305
Hello,
I never thought I would be posting about my old 2305, but I now have to. Earlier this spring I sold my 13 year old 2305 to my neighbor, and now the first time he went out to mow with it the PTO will not engage. I am looking for any info that might shed some light on why the PTO won't engage. I have checked with attachments off and neither the mid nor rear PTO wants to start. The tractor was in neutral and the park break on. When I put the PTO into the rear setting the rear PTO is firmly in place, and spins easily when the PTO is set for mid only. My first inclination was that we have an electrical issue that is not engaging the PTO clutch. I called the dealer and they stated that it sounded like a "hard failure and the clutch might need replacing. I find this a bit suspicious as the PTO spins just fine when not in gear.
I sincerely appreciate any and all input I can get,
SI2305
   / JD2305 PTO will not start #2
I was reading about it on another forum, one guy had the same problem- said it was a fuze to the switch. He stated to engage the pto then take weight off the seat. If the tractor dies, the switch has power and it’s most likely the solenoid that’s bad. Just repeating... mines a 2010, sounds a little different than a 2013. I don’t have a light on the dash when the PTO is engaged. Be interested to find out what is is/was.
Bill
Wvantti,
Thanks for the reply. I, too read about the possibility of the solenoid being bad. We did check the fuses and they were all good, so that makes the solenoid seem all the more likely. Actually this tractor is a 2005 (13 yrs old), so I bet that they are actually pretty similar. I will definitely pass this info on to my neighbor.
Thanks again,
SI2305
Problem SOLVED!!
It turns out this potentially disastrous malfunction was a very simple fix. The Solenoid was simply stuck. With about 3 taps of a hammer to screwdriver to solenoid from the rear and the PTO started working again. It had not been run in about 6-8 months and it likely just froze up. This turned out to be a simple, no-money fix.
SI2305
   / JD2305 PTO will not start #5
Thanks for the update. I was thinking electrical, seat switch solenoid, connector loose/off, chewed/broken wires.
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
2014 KALMAR 4X2 YARD DOG (A50854)
2014 KALMAR 4X2...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
