JD2305 MMM problem
   / JD2305 MMM problem #1
Vin Kelly
My 60 inch midmount mower deck drops 2 inches after the control knob has been set to the highest cutting position. ANY IDEAS AS TO WHAT IS CAUSING THIS?
   / JD2305 MMM problem #2
Vin:
Drops 2" from what? The highest lift from the 3pt Rockshaft control? The hydraulic lift? If it's two inches lower than that that's probably about right.
If you mean once you set the deck height then lower it it drops again then something is wrong.
   / JD2305 MMM problem #3
My guess is that one or more teeth on your height adjustment knob/cog is broken. My mind is drawing a blank as to the exact name for the cog but I have attached a photo for reference. If you remove the mower deck, raise the 3pt, and play with the height adjustment knob while looking on the underside you will immediately see what I'm talking about. One of the teeth on mine is broken and the the deck drops lower than it should. Adjusting the height knob either one step higher or lower is ok. I haven't got around to replacing mine yet as I still need to spend a bit of time assessing how to disassemble to replace most efficiently.
If you adjust the knob one or two steps away does it behavior properly?
If your machine is new, your height knob may not be aligned properly. E.g. the max height is really setting it to the install position instead of max height/install. It may be as simple as a misaligned decal. This doesn't sound like what you are describing, and if this is a developed problem, then obviously this wouldn't apply.
Good luck
   / JD2305 MMM problem #5
I wish Deere would not sell MMM for the 2305. Judging by the complaints it MUST be a poor design.
Willmar 4300 Wrangler Loader (A51039)
Willmar 4300...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
2015 Timpte Hopper Bottom (A50514)
2015 Timpte Hopper...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A51039)
2-Row Peanut...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
