Mowing Jd2305. 54C mower deck bolt
   / Jd2305. 54C mower deck bolt #1
Wvanatti
John Deere 2305 (2010)
My 2010 JD2305 has a 54C mower deck. One of the mower blade bolts came loose and damaged the threads. I want to make sure I order the correct one.
This is what I found “19M7872 John Deere OEM Blade Bolt M12x25”.
But the picture just doesn’t look like it’s correct.
Anyone ever had to replace one ? Any part number? I have my books, but it only shows the bolt and torque. No part number. Thanks
   / Jd2305. 54C mower deck bolt #2
That sounds correct. I have a 62D deck but I think the design is similar. Mine has M12 bolts and 25mm length seems correct because they are about 1 inch long.
If I were you, I would just go to the local hardware store and pick up a M12 x 25mm bolt and try it out. After all it's just a bolt. John Deere doesn't have magic bolts.
The only variable on metric bolts is thread pitch. I would guess a M12 is 1.25 pitch, but take the old bolt in and compare to make sure.
Thanks for the input. I was just being lazy to not drive 3 miles to a store. Was going to order off line. I retapped the old one to get by with.Torqued right down.
Was just going to order a few for spare if I knew for certain the correct size.
Thanks again for the reply.
   / Jd2305. 54C mower deck bolt #4
Thread pitch is 1.75mm. You need grade 10.9. JD dealer price is $1.28 each. You can get 10pc for $6.94 plus shipping from McMaster-Carr, P/N 91310A709
Thanks. I will order some. Appreciate you taking the time.
JOHN DEERE 6500 HI-CYCLE SPRAYER (A52708)
JOHN DEERE 6500...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
2020 Case 5550 Trident (A56435)
2020 Case 5550...
JOHN DEERE 700 HI-CYCLE SPRAYER (A52708)
JOHN DEERE 700...
1300 (A58374)
1300 (A58374)
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
