Mowing Jd2305. 54C mower deck bolt
   / Jd2305. 54C mower deck bolt #1
Wvanatti
John Deere 2305 (2010)
My 2010 JD2305 has a 54C mower deck. One of the mower blade bolts came loose and damaged the threads. I want to make sure I order the correct one.
This is what I found “19M7872 John Deere OEM Blade Bolt M12x25”.
But the picture just doesn’t look like it’s correct.
Anyone ever had to replace one ? Any part number? I have my books, but it only shows the bolt and torque. No part number. Thanks
   / Jd2305. 54C mower deck bolt #2
That sounds correct. I have a 62D deck but I think the design is similar. Mine has M12 bolts and 25mm length seems correct because they are about 1 inch long.
If I were you, I would just go to the local hardware store and pick up a M12 x 25mm bolt and try it out. After all it's just a bolt. John Deere doesn't have magic bolts.
The only variable on metric bolts is thread pitch. I would guess a M12 is 1.25 pitch, but take the old bolt in and compare to make sure.
Thanks for the input. I was just being lazy to not drive 3 miles to a store. Was going to order off line. I retapped the old one to get by with.Torqued right down.
Was just going to order a few for spare if I knew for certain the correct size.
Thanks again for the reply.
   / Jd2305. 54C mower deck bolt #4
Thread pitch is 1.75mm. You need grade 10.9. JD dealer price is $1.28 each. You can get 10pc for $6.94 plus shipping from McMaster-Carr, P/N 91310A709
Thanks. I will order some. Appreciate you taking the time.
2014 Chevrolet Silverado 1500 Pickup Truck (A48081)
2014 Chevrolet...
2025 KJ K1230 UNUSED (10) Wire Mesh Netting Rolls (A50860)
2025 KJ K1230...
2014 Range Rover AWD SUV (A48082)
2014 Range Rover...
2014 Ag Spray Schaben Sidedresser (A51039)
2014 Ag Spray...
2013 Chrysler Town and Country Touring Van (A48082)
2013 Chrysler Town...
Cyclone 4826 Sand Blast Cabinet (A50860)
Cyclone 4826 Sand...
