Grading JD2210 rear blade guage wheels
   / JD2210 rear blade guage wheels #1
bmclernon
Denton, MD
JD 2210
I have a 5ft KK rear blade. This past week I had my first opportunity to "play in the snow" on my gravel drive. Since 3ph height control is somewhat lacking with the JD2210, I was wondering if anyone knows of guage wheel assemblies which could welded/bolted to the to the blade
   / JD2210 rear blade guage wheels #2
Just an idea, you could weld a piece of pipe or tubing vertically on each end if the back side of the blade. Have several holes for height adjustment and use a pin to hold your wheels in place like is used on a mower deck. Kinda hard to explain whats in my head, but if you look at a mower deck gauge wheel and transfer the same principal to your blade. I'd make them so that the wheels are easily removed or up high enough to not interfear with regular blade useage.
Good luck and let us know what you come up with. /forums/images/graemlins/cool.gif
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A52748)
UNVERFERTH 330 8...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2014 Ford Taurus AWD Sedan (A50324)
2014 Ford Taurus...
