jd2030 allmost no lift or steering when hot
   / jd2030 allmost no lift or steering when hot #1
jdan
loganville georgia
john deere 2030
jd2030mannheim poor lift and steering when cold after twenty minutes running hardly any lift or power steering. no hi-lo shifter or reveser on tractor. filters clean,oil filter relief good. need help!
   / jd2030 allmost no lift or steering when hot #2
I'm no expert, but I'd be suspecting the pump seals - when the hydraulic oil & pump warm up, the metal expands and if the seals are faulty they will not hold the pressure...
I'm sure someone else here will be able to give you more detailed advice - try looking for JJ...
   / jd2030 allmost no lift or steering when hot #4
It could be a filter in the closed center pump that can become clogged and prevent the pump from going into stroke, it could be the CC pump going out, or you likely have an OC "transmission" pump that feeds the main pump and lubes the transmission that could be going out.
2020 Kia Sportage LX SUV (A50324)
2020 Kia Sportage...
2023 John Deere Z994R (A50121)
2023 John Deere...
PICKUP TOOLBOX (A52472)
PICKUP TOOLBOX...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
Kelly Ryan 2W-14 Bagger (A50774)
Kelly Ryan 2W-14...
2015 Ford Fusion Sedan (A50324)
2015 Ford Fusion...
