jd2030 allmost no lift or steering when hot
   / jd2030 allmost no lift or steering when hot #1
jdan
loganville georgia
john deere 2030
jd2030mannheim poor lift and steering when cold after twenty minutes running hardly any lift or power steering. no hi-lo shifter or reveser on tractor. filters clean,oil filter relief good. need help!
   / jd2030 allmost no lift or steering when hot #2
I'm no expert, but I'd be suspecting the pump seals - when the hydraulic oil & pump warm up, the metal expands and if the seals are faulty they will not hold the pressure...
I'm sure someone else here will be able to give you more detailed advice - try looking for JJ...
   / jd2030 allmost no lift or steering when hot #4
It could be a filter in the closed center pump that can become clogged and prevent the pump from going into stroke, it could be the CC pump going out, or you likely have an OC "transmission" pump that feeds the main pump and lubes the transmission that could be going out.
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2024 Icon I40L Electric Cart (A50324)
2024 Icon I40L...
2005 Nissan Pathfinder SUV (A50324)
2005 Nissan...
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
CAT Skid Steer (A50322)
CAT Skid Steer...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
