jd180 quits after 30min. of mowing
   / jd180 quits after 30min. of mowing #1
engraver1
new albany ohio
john deere 180
I start mowing, runs great. 30-45min. later it wants to quit.
I have to jack the throttle back and forth to get it to the barn.
i have replaced-gas cap,fuel pump,ignitor,fuel filter,air filter,plug,took carb
off and cleaned. could the coil be getting hot and quitting?
i think that is my next step since i already bought the coil.
i dont know what to do next.
any help would be greatly appreciated.
thanks
engraver1
   / jd180 quits after 30min. of mowing #2
Yes, I believe the coil is the culprit. Do you lose spark when it quits? All those other things you did could have been avoided if you would have checked for spark. Not in vain though, they may have needed changed/cleaned anyhow.
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
(INOP) BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51247)
(INOP) BOMAG...
(APPROX 24) 2" X 6" X 60" CHANNEL IRON (A51247)
(APPROX 24) 2" X...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
