JD1520 loses brake pedal
   / JD1520 loses brake pedal
When we bleed the brakes, they are disconnected from each other and bled individually.
Both sides are equally low and both are required to be bled.
Agree that air is getting into the hydraulic fluid somehow.
   / JD1520 loses brake pedal #12
As I previously stated I think the 1520 brake valve body & internal components is a little more complicated than an automotive type master cylinder. Trans pump supplies oil IE fills brake valve housing but in no way powers brakes with hyd pressure.
May I ask what you're referring to as the proportioning valve?
Notice that JD offers a brake valve overhaul kit (AR54929).....which is a bunch of O rings and a seal.
The brake valve on the tractor does not show any leaks, so not sure that would help. Any thoughts ?
   / JD1520 loses brake pedal #14
Having served over 13 yrs as as a JD dealer service manager my experience is that problems with JD utility tractor brake valve similar to 1520 was due to valves inside of housing that fail to seat properly or brake pedal height not adjusted correctly. This is presuming axle brake piston seals are good.
Thanks Jim for your input. Once we finish the mowing for this year, will work on rebuilding the brake valves on the tractor. Will report back what happens.
Thanks again.
2017 Ford F-150 XLT 4x4 Crew Cab Pickup Truck (A55973)
2017 Ford F-150...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A58018)
2020 INTERNATIONAL...
NEW Landhonor Diamond Dry Drill Set (A59000)
NEW Landhonor...
2019 Freightliner M2 106 AWD Terex Hi-Ranger TC55 55ft Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
TANK MANIFOLD (A55745)
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
