Oil & Fuel JD140 Fuel Leak
   / JD140 Fuel Leak #1
Anonymous Poster
Epic Contributor
I have a 74 JD140 that has fuel leaking out of the Carb. bore while it is not running.
Any ideas?
Thanks.
   / JD140 Fuel Leak #2
Sounds like the float and/or float needle is sticking. You might try some carb. cleaner additive. It could be the float is out of adjustment or the needle is worn but most likely the float sticking just enough to let fuel pass the needle when it's not running.
Billy
Unused 2025 CFG MX12RX Mini Excavator (A49461)
Unused 2025 CFG...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
RoGator 844 sprayer (A50490)
RoGator 844...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
