JD112
   / JD112 #1
nobody cares
2005 husquvarna
I have a jd 112( around a 1975 ) that has a hydralic lift. i had to put about a half pint of hyd. oil to fill the tank , still will not lift the snowblower. Anything else i should check to see why the hyd. are not working ??? Thnx Dave
   / JD112
Maybe you don't remember back in the day, People would come back with nobody cares. Just a old saying . Dave
   / JD112 #4
is it leaking oil? is the hydraulic cylinder working when you actuate the cylinder? is the drive belt slipping that goes from the engine to the pump?
   / JD112
Thnx for the reply. Got er fixed yesterday. Did a little tweeking , and whalla everything working. Hydralics and snowblower are working nicely. Snowblower is pretty loud. Maybe because of the chain drive auger. Will have to tweek on it a bit. Dave :thumbsup:
   / JD112 #6
take the chain cover off the RH side of the blower and make sure its tight. Shouldnt sag more than 1/2 inch or so. adjustment is on the RH side of the mount. Its on the shaft from the drive pulley. Give the shaft and the chain a couple shots of multipurpose grease.
   / JD112
Ok, thnx for the info. I'll check it out. Dave :tractor:
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2012 Ram 1500 4x4...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
LIGHT BAR AND WIRING (A50854)
LIGHT BAR AND...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
