Rotary Cutter JD1025R Brush Hog shear pin vs slip clutch
   / JD1025R Brush Hog shear pin vs slip clutch #1
rkallaman
KNox, Pa
JD 1025R
Does anyone running a JD1025R have trouble breaking shear pins on a 4ft. brush hog? If so do you have a solution?
   / JD1025R Brush Hog shear pin vs slip clutch #2
It isn't necessarily a tractor problem. One of 2 things, on many Deeres for a long time, the E pto causes the pto to start and stop abruptly, It doesn't modulate on slowly or wind down (PTO) when disengaged. Therefore when putting a cutter on a Deere, it is always recommended to go w/ a slip clutch.
The second possibility is what you are cutting or trying to cut. It doesn't take a lot to shear a pin. Maybe raise it up some to get off ground more.
   / JD1025R Brush Hog shear pin vs slip clutch #3
Hopefully, you'll see my note to you under my throttle problem thread.
None broken so far.
Ralph
   / JD1025R Brush Hog shear pin vs slip clutch #4
I usually slow my tractor rpms before engaging the implement. Use grade 8 bolts which Deere specifies in other bolt applications as when they go you get a clean cut and can find the pieces to dig out. I use a lock nut (regular nut with a nylon insert) and don't tighten it all the way. I leave a little slack such that you can wiggle the bolt when finished installing. They don't last very long if I run them up tight and torque them. I guess it has to do with the interface of the shaft to the collar.....slop.
I prefer bolts to slip as I can depend on the bolt. The slip, who knows. Will it or won't it even if you do that annual maint and adjustment on them. BTDT
HTH,
Mark
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A56138)
2014 INTERNATIONAL...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
Rooster Wooden Statue (A55853)
Rooster Wooden...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
