JD ztrak 445 problem
   / JD ztrak 445 problem #1
bc69ss
Hannibal, MO
z445
I have a 2010 JD 445 zero turn mower with 159 hours on it. It has the 25 HP Kawasaki engine. I live on the side of
a big hill so all of the mowing is on a hillside. While I was mowing today I noticed the right wheel gradually start to
lose power. Within a couple of minutes it would barely pull itself up the hill and I started to smell something burning.
I stopped, backed it up and it took back off forward. It seemed to have more power to that wheel after I backed up and
restarted. I took it up, cleaned everything up with a pressure washer and tried it again. I tried to take it up a little hill
and it wouldn't pull itself up.
Hopefully someone has experience with this and can help me out.
Thanks in advance!
   / JD ztrak 445 problem #2
:welcome: to TBN
With power to only one wheel of a zero turn, you must just go in circles.
When you mow your hillside, do you just go up and down, and not across the slope?
:welcome: to TBN
I can mow across, @ a 45 degree angle or up and down. It really isn't hard to control.
But now like you mentioned only circles. :)
Kubota LA525 Front Loader Tractor Arm Attachment (A55851)
Kubota LA525 Front...
2021 Versatile 405 Tractor (A53485)
2021 Versatile 405...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2015 Komatsu PC138 (A47477)
2015 Komatsu PC138...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
