jd z997 vs kubota zd331
   / jd z997 vs kubota zd331 #2
I've only looked into the JD, so I'd go with that off the top of my head. But have done no looking into the Kubota. JD looks to be a really sweet machine.
   / jd z997 vs kubota zd331 #3
I've got a ZD331 and it's been awesome but John Deere makes great equipment also. I don't think you can disqualify either one based on specs or reliability. Other brands maybe, but these are both great machines. I think you'll find it comes down to a personal preference after you drive them.
i just seen threads before owners of zd331 saying that it ran hot
i have a bx2360 that i was going to trade in for the zd331 to kubota
i really have no use for it anymore. not even a year old yet
john deere doesnt want it. havnt had any luck trying to sell it
but john deere wants my z930a and giving good trade in value
i wanted to upgrade to diesel which is my main reason for changing
   / jd z997 vs kubota zd331 #6
The rest of the story on this is that the owners that had machines running hot failed to clear the dry grass and other debris from the screen in front of the radiator. This quick step, coupled with watching the temperature gauge will eliminate any problem. This is covered in the operator's manual.
thxs i figured most of it was due to lack of cleaning
i blow mine of after every cut and air filter
   / jd z997 vs kubota zd331 #8
At one time, I ran a ZD25 and ZD28 in my business. Several times I had to stop and let the 28 cool down. The radiator screen builds up and just overheats the engine. I mean from one yard to the next I had that problems thru the hot summer. Now since May of 2009, I have been running a 997. I have never had to blow the screens out more than once a week. Other than a pulley bearing at around 400hrs (covered under warranty) I have had zero problems with my 997. Now it has 1400 hrs and going as strong as hour 1!!
Only thing I hate on the 997 is the deck lift. Its a push button electric lift, you push the button with your right foot and the deck lifts and rotate a knob to set cut height setting, then release button and deck drops to that setting. If mowing and you want to raise up over a tree root or whatever, you push the button and the deck comes up as long as the button is pushed, release and the deck drops fast. You cant just raise a little bit and hold, its either all the way up or down. The Kubotas use hydraulics to raise and lower with a hand lever. You can raise or lower how ever as much as you want. I miss that.
The 997s have big ole fat butts on them. Huge hood back behind you that are expensive to replace if you need too, you just dont have good vision right behind in close quarters. Kubotas are more stream lined in their design. The 997s seem to be heavier too. You just have to sit and run both and see which one you like better, and investigate the dealers too!
kubota has a 32 gal gas 3 cylinder zg332
wonder if I should b looking at a more horsepower gas than diesel
wonder if the zg332 would burn a lot more gas than diesel
2012 RAM 5500 (A52472)
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
2017 Ford Transit 250 Cargo Van (A50323)
2017 Ford Transit...
John Deere 1025R Tractor (A50514)
John Deere 1025R...
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
2015 GMC Acadia SLT1 SUV (A50324)
2015 GMC Acadia...
