Mike VS
Hi guys, Kinda new here so bare with me...
I have a JD X749 - 4 wheel steer/ 4 wheel drive diesel powered mower that is the best thing since sliced bread! I have had it for over a year and put near 50 hours on it with zero problems.
Now I do... While mowing today it suddenly died from full RPM. It did the same thing last month at which time I freaked out and parked it while I pondered the problem. At that time I tried restarting it after a 1/2 hour and it immediately fired up and continued running until today. This time when it died I gave some quick testing to discount possible problems. When it died I immediately tried restarting... Yup, fired right up and continued cutting for 2 minutes until it started dying again. This time I disengaged the PTO (cutting deck) to see if there was any load problem. Nope, just finished dying out without any effect. Again it restarted right back up and soon died again in a few minutes. I tried to throttle back while disengaging the PTO again. Zero effect as it just petered out from full RPM. This time I stopped, opened the hood and checked the obvious; Oil good, coolant good, temp very good running with gauge at 50% mark, air cleaner good, all hood breather screens clear. Fuel level above 75%, Nothing found at all, but there was a bigger gap this time before restarting it (just like last month). Again it fired right up with no hesitation and continued cutting until I finished 15 minutes later.
I know gas engines pretty good but I'm new to diesels. It acted like it lost spark but that obviously is not the case. There seems to be a correlation to the amount of off time before restarting. I did the maintenance about 20 hours ago changing the oil, fuel and air filters. Also the seat cut out switch has been disabled so I don't think it's that.
I'm wide open to suggestions if anybody has any guesses. Thanks
